Rear Mudguard Adjustment
GJT
Is it possible to adjust this, so that there is minimal equal clearance on the full length of the mudguard?
If so, what do I need to? If you look at the pic you will see what I mean
Mo1959
Looks like you will have to snip half an inch from the topmost stays. They are usually quite hard so decent bolt cutters would be ideal.
G
GJT
They are Whyte mudguards specifically for the R7/RDZ range of bikes, so I thought stays would have been supplied at correct length.
Thanks for the advice
youngoldbloke
Can you turn the light upside down? Looks like it might be more vertical if you could. Failing that could you fix it to the seatpack. Not a lot of use pointing skywards. I have the samre problem on my winter bike. I managed to find a neat German light/reflector combined that fits on the mudguard, but it is not very powerful. There are a lot of lights around that are designed to fit on the seatpost, but not many that fit properly on the seatstays.
G
GJT
The barrel shaped bit at the end of the stay, is that some sort of adjuster to move them in and out?
Yes, the stay can move a bit and then tighten the adjuster up, but I've tried that to no avail- it's in as far it will go now. It was my LBS that fitted them, but thought I'd ask on here first, in case it was something dead simple I was missing. I think I'll just take it back there before taking Mo1959's advice
G
GJT
See pics from rear- I think it's more pointing towards car drivers, than skywards. I do have another light fitted to saddlebag.
betty swollocks
large member
First of all, swap the stays over so that the uppermost two are now the rearmost and vice versa, then chop the two which are now the rearmost, to the contact length.
Getting mudguards just right is one of the most fiddly bike-fettling jobs, if you ask me and a bit of judicious bending sometimes helps too.
