T.M.H.N.E.T
- Northern Ireland
Why don't you provide the specific part.Because it no longer meets legal requirements being the main reason. Suggest you check the lighting regulations,
Really bright lights, also cheap and last quite a long time on a set of batteries.
You only require 1 light in either direction to be legal, any others you have do not need to follow the same standards or testing.Front Lamp
One is required, showing a white light, positioned centrally or offside, up to 1500mm from the ground, aligned towards and visible from the front. If capable of emitting a steady light, it must be marked as conforming to BS6102/3 or an equivalent EC standard.
If capable of emitting only a flashing light, it must emit at least 4 candela.
Rear Lamp
One is required, to show a red light, positioned centrally or offside, between 350mm and 1500mm from the ground, at or near the rear, aligned towards and visible from behind. If capable of emitting a steady light it must be marked as conforming to BS3648, or BS6102/3, or an equivalent EC standard.
Part of the certification process involves the construction. Modify how the manufacturer has put the thing together & it will no longer meet the required standard(s). Try sending a light back, as being faulty, after you've modified it and see what happens.
I bought some SMART front and rear lights once. I thought they were good until they fell apart. Lost 3 rear lights as the lenses came off the bodies as I went over uneven surfaces. Lugs broke. Awful build quality. Buy cheap buy twice. Exposure lights are the best on the market, very very bright and extremely well made.
The SMART rear I have is absolutely fine and well put together.
I really like the Smart rear lights, got a few including the R1 and Superflash, never had a problem with them apart from my old favourite R2 that came out of it's bracket at 30mph down a steep hill, I didn't bother going back to pick up the pieces![]()
Front Lamp
Rear Lamp
I have the Knog Blinder Road Rear Light as secondary light and I rate it highly. 5 modes and LEDs angled for seat post use.
Specs
- 70 Lumens in strobe mode
- Light Dimensions: W27mm x H76mm x D52mm
- Weight: 52g
- UV-Resistant, industrial-grade Silicone Rubber Body and Straps
- Polycarbonate Housing
- PMMA Lens
- Anodised Aluminium Heat sink
- Anodised Aluminium Fascia and solid Stainless Steel MIMLatch
Cost: 32 quid - a bit over budget.
- Rechargeable Lithium Polymer (USB)
Downside: Can't clip to saddle bags or racks.
This seems better value at £17.99 http://www.ebay.co.uk/itm/380752934091?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
1 Watt, USB rechargeable, limited lifetime warranty, clip to fit anywhere.
Def better mounting options - just not as bright.
Pretty damn bright to my eyes. Is there are Lumen / Watt formula of comparison chart?
As long as it does for you it's all good. To my mind rear lights when on road are actually more important than fronts...
It depends how hard the LEDs are being driven, optics, angle etc. The Knog pushes them pretty hard - hence the poor battery life on the higher settings (only 4-5 hours) - battery capacity is also not huge either. My powerful rear light (a torch) pumps out 150 lumens, but only lasts for 95 mins as it is being driven at 1.4A.
I worry more about being hit from behind (hence two powerful rear lights), but it's more likely an incident/collision will happen in front of you. For that reason, I'd go with a powerful front light too!
I agree. I worry more about getting hit from behind so that's why I always run rears night or day. To avoid SMIDSY. Pretty sure in general I get given more room.
Unfortunately you can't help some moronic car drivers. I have been out of action for over 2 months thanks to an idiot deciding to turn left, without indicating, or checking his mirrors. Annoyingly is was under 400 metres from my house and I was only travelling about 14 MPH.
Straight over bars to swerve out the way - nicely landing on my wrist and snapping the Scaphoid bone clean in two! Cheers
