Yellow Saddle
- Loch side.
You've answered your own question. You'll see this only happens when you back pedal AND the chain is on the biggest sprocket. In that position the chain's angle from the top of that sprocket to the chainring in front is at an angle big enough to make the chain want to "correct" it when backpedalling. This doesn't happen when you pedal forward because then the chain enters the sprockets from below and the derailer cage is designed to correct the chainline before it goes onto the cassette. When backpedalling, the chain enters the cassette without the benefit of pre-correction by a derailer.
