If you want to harm your Brompton you should buy these. Brompton had a support document for many years regarding this. Recently they reorganized their support pages and a lot of older articles including the one in question got lost. This is what they said:
PAINT FINISH
The steel frame parts on every Brompton bike are powder-coated (rather than using a wet paint) in order to give an even and durable finish. The powder is sprayed at the frame part and attached with an electrostatic charge, it is then baked in an oven to melt and adhere it to the frame. (...)
DURABILITY
Before painting, each frame is pre-treated with a chemical anti-corrosion treatment. This protects the bare metal and prevents any surface corrosion that may develop, penetrating through the metal. Often visible in the open tube ends, this rusting is on the inside of the frame tubes and is purely cosmetic than a structural problem. The electrostatic spraying of powder paint means the powder cannot enter into the inside of tubes easily and means that there is no paint on the inside of tubes beyond the first 3-10mm. Consequently, the inside surface of the frame on a Brompton is unpainted and can appear ‘rusty’ but this will only be a surface discolouration due to the chemical anti-corrosion treatment.
As the steelwork is protected from corrosion there is no need to apply any rustproofing or similar to seal the tubes. Blocking the ends of the tube can do more harm than good and can actually trap moisture inside the frame and not allow it to breathe. Wiping with an oiled rag will lessen the appearance of this yellow-red colouration.
Original source (no longer avail):
https://brompton.zendesk.com/hc/en-...-Raw-Lacquer-Flame-Lacquer-Our-Paint-Finishes
I am always baffled about the amount of people that seem to think that the people at Brompton would be complete idiots that produce a bike for 35 years w/o any thinking so that it will break within minutes and over the whole time no one recognized it whereas they themselves are so incredibly clever that they immediately, literally minutes after aquiring a Brompton (or even w/o ever having owned, ridden or sometimes seen one), identify the obvious weaknesses of the concept and know how to make it better. You should really learn that loads of people are selling snake oil. They make a living from that. Some w/o even understanding that they are selling snake oil.
