folks
im having a wee problem getting the indexing on my rear derailler correct. i dont want to put it into the shop as i want to
learnhow to do this myself.
heres what im doing
chain is on the middle front ring ( its a triple), back small ring
ive undone the pinch bolt and turned the barrel adjusters clockwise on both the derailler and the shifter so the cable has the most amount of slack.
ive pulled the cable at the derailler reconnected the pinch bolt. ive then clicked the shifter to take the chain onto
the seconed sprocket at the rear and slowly turned the barrell adjuster anti clockwise untilthe chain jumps onto the second sprocket
fine!!!.. the chain moves up the gears fine, but coming back down the changes are very sluggish and at the last click it wont drop onto the smallest ring!!!!!
any idea what im doing wrong??????????????
thanks
heres what im doing
thanks
