The level of detail makes that a very interesting post.
Basically it could be seen as the "price" of wanting a narrower chain in order to get more gears.
From a mechanical viewpoint, a weakness due to less material withstanding a same force.
A countersunk connection implies less material than a protruding one.
Abit the same story as the 15t version of a brake disc bolt on rear cog for fixed gear, due to common hexagon bolt heads voiding space that the chains links need to engage, countersunk bolt heads and corresponding drilled holes in the cog are used, which also lowers the force required for a rip off.
Still I wonder what actually happens in the case of peen not breaking off - the case of < 9 speed, when a pin is pushed out (chainbreaker). Basically it's pushing a thing through a hole that is too small for the thing. Somethings gotta give (by deforming). But what? Pin, plate, or both? And is that deform temporary (elasticity) or permanent? The production-peening is certainly permanent, but the applied force could be the reason.
Steel is hardened. Hardening comes at the "price" of a reduced elasticity in the hardened part (surface). Does the hardening degree (depth-"case depth") of pins differ from that from plates? I gave a hammer blow on the pin end that I pushed forth and back. I didn't notice something visual in both before and after (pushing pin forth and back and hammer blow). But the difference may have been below visual recognition.
