Dogtrousers
Kilometre nibbler
Last weekend I broke a spoke in my back wheel, so on Saturday I transferred the cassette (Shimano 11S) over to my spare back wheel. The same cassette has worked perfectly well on that wheel before, but now it wouldn't engage the bottom 34t sprocket. It was as if I'd forgotten the spacer, which I hadn't (I took the cassette off again to double check). So on Sunday I tried again and had to slacken off the LO end stop a bit and fiddle with (tighten) the back-and-forth adjuster (is that the B screw?) til I could get it going. HI stop seemed fine, it's not over-throwing past the small sprocket.
Now, I'm paranoid about fiddling with the end stops. To my mind they are to be set once on installation and don't need changing. I'm especially paranoid about the LO end stop because of the danger of putting the mech into the spokes, so it felt very wrong to be doing this. As a precaution, at the end of my bodging session I re-tightened the LO screw until it didn't work any more then slowly slackened it until it just worked.
What's bugging me is whether I've been bodging beyond my abilities. I know my limitations when it comes to bike bodging. Why should this have been necessary? The bike has a steel frame with integral hanger, so the immediate response of "your hanger is bent" does not apply. As far as I know the mech has not been bashed. The mount bolt, which came loose about 18 months ago and needed re-tightening, was still rock solid.
Mech is RD-r7000-GS. About 4 years old. Stops were last adjusted when it was installed (by someone who actually knew what they were doing).
Any thoughts on what might have been going on?
