rattling crank on spec sirrus
drewc65
bristol
As the title suggests. I have a noisey crank on my sirrus. When you put pressure on the pedals. When going up hill it makes a kind of creaking sound And the same when pushing on a little.
also check saddle , oh and see hear
http://www.jimlangley.net/wrench/keepitquiet.html
cyberknight
1st port of call would be to grease the pedals, i had the exact same problem and after much fiddling i just re greased the pedals and the sound went.
drewc65
drewc65
bristol
Will give that a try and going to do same with seat post seems a common problem on these bikes strangely. Thanks
