Hi,
I recently came off my bike. It is a boardman comp racer. I think the nut on the left side of the bike took a hit due to a deep scratch on it. It was fairly loose when I went around to check the tightness of the bolts. My bike is generally quite quiet but now has a rattling sound throughout all gears around the rear derailleur cogs. It is also not fluidly moving between gears and I can't get it in the top gear.
Does anyone know what I could do to fault find the problem or direct me to where the problem is situated?
I also tried moving the barrel adjuster to see if it would make any difference but it made it worse if anything.
Thanks
Thanks
