This is quite a messy subject.
Traditionally, in the UK, gears are expressed in "gear inches", which is the wheel size of an equivalent "ordinary" (penny farthing) bike. Typically around 30" is a low gear, and over 100" are high gears.
Traditionally, on the continent, gears are expressed as "développement" which is the distance in metres that the bike will travel for one rotation of the pedals.
Ratio is less useful, because the actual "highness" or "lowness" of the gear is dependent on both the ratio and the wheel size. So a given ratio on a road bike would be a totally different gear on a Brompton. But both of the above (inches and développement) would be the same on both.
Sheldon Brown writing on the subject
here. A good explanation of existing systems and a quixotic proposal for a new one.
It doesn't really matter what system you use as long as other people understand you. On the fixed gear forum people happily discuss riding a (say) 64" gear and understand each other. I doubt any of them has any idea, or cares, what a 64" penny farthing would look or feel like.
I've never seen the gear calculator that
@Ajax Bay referenced, and it looks great. Almost, (but not quite
), as good as my venerable gear calculating spreadsheet.
