hopless500
Trundling along
- not-as-flat-as-you-think Norfolk
That is very true!What is bike maintenance but an excuse to buy more tools?
For all I know Mr Hop has one of these. But I can't say I've ever seen one.
And you were sure you didn't ask a question about having a baby.What is that???![]()
Forgot to say, I do like your 'springy thing' and 'sockety thing' - language I fully understand and utiliseThe springy thing is a "third hand" that holds the brake clamped on while your other two hands do other things. The L shaped thing is the inverse allen key, sockety thing that I mentioned.
Scarily, I think it does! So in fact it might well be ok.In the rear dropout on the drive side will probably be the "claw" bit of the rear mech. This has a U shaped bit that the axle goes into that actually sits a bit forward of the very rear of the dropout itself. So the axle goes right to the back of this, but on the non drive side is about 5mm or so forward of the very back of the dropout. Does that make sense?
. Took off, cleaned and sorted back brake. That took AGES to centre. Absolutelyflippin' ages. Needs a new chain, but have given the old one a clean and some lube. Straightened a bent bit on the front derailleur which was catching. All the gears are changing well (on the whole). They probably need more investigating, but I'll wait until I've tried them out on the road.
I think a size down would have been better, but it's too late now. Modern saddle going on - comfort over aesthetics at this point! (but I'll keep the old saddle to one side).
so I quickly washed that off. White spirit did the same. WD40 sort of loosens it a bit if I wait ages and then scrape with a fingernail. But that is going to take weeks to do like that. Anyone have any good ideas???
