Raleigh royal tourer rebuild
Gunk
Gunk
Oxford
A few bits arrived this afternoon
525943
Gunk
Gunk
Oxford
Next job is to deep clean and polish the bare frame and forks, build up the frameset ready to reassemble
Gunk
Gunk
Oxford
This afternoon I concentrated on the frame and forks, using a mixture of WD40, fine wire wool, cutting polish and Autosol, it’s come up rather well considering how bad it was.
526211
526210
Next job was to build up the BB and headset, no dramas as I’d already cleaned and prepped everything, I used loose ball bearings and I’m really pleased both run super-smooth, the headset has a nice serrated washer which locks the adjustment ring which means you don’t over tighten the headset when you tighten the lock nut. I’ll see if I can get hold of a set of these for the next project as they make adjustment so much easier.
526215
