ChrisEyles
- Devon
Having a few problems with the Raleigh dynohub on a wheel I recently acquired for an on-going restoration, and wondered if any fellow enthusiasts here might be able to help me out.
I started by seeing if the headlamp that came with the hub would produce any light when connected up.... and so far no joy - but I'm definitely not ruling out user error yet. Are there any points to be aware of (e.g. do the red/black wires need to be connected to the correct terminals), or should it just be a case of connect-and-go?
I'd also like to switch the bulb over to a more functional LED, and add an appropriate rear light at a later stage. If anyone's able to offer some properly idiot-proof advice on how to go about this, I'd be much obliged. My friend did draw me a circuit diagram when I asked him, but I can only hope he was massively over-complicating things (he is in the middle of a PhD in electronic engineering, and given his personality this seems quite likely), since I didn't understand a word!
Secondly the bearings feel extremely "coggy", even when I back the LHS cone all the way off. Is this just the normal resistance of the magnet in the dynohub, or does is mean the RHS bearings have somehow bound together or some other problem with the hub?
Thanks for the help! Still got quite a lot of cleaning up etc to do, but looking forward very much to finally putting the bike in question together, even more so now I've got the dynamo hub front wheel and 3-speed SA hub rear
