Peter Salt
Bittersweet
- Yorkshire, UK
I'm planning a new bike build and have an opportunity to get a used R9100 groupset on the cheap. I've some questions around the rear derailleur capacity for this model. Manufacturer specification says:
Which is identical to the R8000 'short cage' version.
The R8000 'medium cage', which I normally use, has a wider range:
There seems to be no 'medium cage' variant for the R9000 and the only difference between the 'short' and 'medium' for the R8000 is the size of the cage (i.e., the derailleur body itself appears to be identical).
Question: Are the cages on the R8000 and R9100 cross-compatible? I.e. can I take the longer cage from a R8000 and fit it on the R9100? If yes, would that effectively bring it to the spec of the larger R8000?
| Max. front difference | 16T |
| Total capacity | 35T |
| Low sprocket|Max. | 30T |
| Total capacity | 39T |
| Low sprocket|Max. | 34T |
