Quick Release
What is the best way to make sure quick release levers are kept easy to get on and off. What should I use to stop them from becoming stiff and difficult?
MontyVeda
lubricant.... and they don't need to be tight, just taught.
Glasgow
Lubricant? Don't! :stop:
Just do them up not so tight, and close them in a position so that you have leverage from the frame when you need to open them.
Crankarm
Nr Cambridge
You have slow release skewers. You need to buy the quick release versions.
Tim Hall
Crawley
Regarding lubrication - a drop of oil/gt85/other in the lever gubbins (stop me if I'm getting too technical) is probably a good idea. Keep the oil etc away from the bits that clamp the dropouts.
midlife
[QUOTE 5234887, member: 45"]They should be tight enough that they leave an impression in the palm of your hand.[/QUOTE]
Unless you have chromed long dropouts from the 70's and then they have to be tight enough to make your palms bleed :smile:
Shut Up Legs
Down Under Member
Just don't do them too tight. I did that once years ago, and managed to snap the skewer (fortunately not while cycling). It was the axle part of the skewer which snapped, not the lever. But since it snapped while I was pushing the lever in, no harm done to myself, so I was lucky.
si_c
Wirral
Done that too! Long walk to the station!
