I'm not sure if this is a problem or how it's intented to be.
I've set-up my shimano deore disc brake using the red spacer etc.
When I install it onto the disc the disc and brake pads rub slightly (as in theres no clearence between pads and rotor) although it can still run.
I've tried resetting the pistons and have the same problem. I can always slide the red spacer back in.
So for what I can see I have on my hands either:
1) New brake pads so a little bit of resistance is to be expected
2) How its meant to work
3) Its broken
4) I've done something wrong on installation.
(brake is shimano deore m535)
3) Its broken
