Spoons47
- Crawley West Sussex
The right knee at the front just a tad after about 15 miles. It’s my go faster mirror
See the Thread entitled “Am I Sad”
See the Thread entitled “Am I Sad”Rough rule of thumb with saddle height is your leg should be straight when your heel is on the pedal, and the pedal is as low as it can go in relation to the saddle, so the 1st pic looks like the setting is pretty much OK.
There are two more "scientific" formulae I know of for setting height; both are based on the rider's inside leg measurement with no shoes on, and it needs to be fairly accurately taken.
One is top face of saddle in line with seatpost to centre of pedal spindle at lowest point = 1.09 times inside leg. The second one is top face of saddle to centre of bottom bracket = 0.882 times inside leg. If you calculate using both you typically find they both come out within about a quarter of an inch of each other. Every rider is different, but these figures will not be far off the optimum, just set according to the formula and tweak from there.
As regards minor bike shakedown adjustments, personally I don't see much point in doing a 40 minute journey all the way to the bike shop just for a 5 minute tweak. Waste of time unless you have some sort of real issue to resolve, not a trivial one like a control cable needing some slack taking up. Make a cuppa, by the time the tea is brewed you will have done your adjustment and saved an unnecessary journey.
Now that looks like a cycle that just begging to join in on the Local North Sussex section of the Roughstuff Fellowship https://www.rsf.org.uk next rides start in September.View attachment 424345 View attachment 424342 So service booked for Thursday, will be taking it to Wallington on the train and thanks to Vicksters light bulb moment, I will be cycling home to Crawley.
I’ve been tinkering with bike fit, I realise I’m stuck with the hybrid (should have put more thought in when I was buying) but thought I would try and make it more aero whilst still within the parameters of a correct bike fit. With that in mind can anybody give any thoughts to my leg angle in 2nd pic, do you think I should go tad higher with saddle? 1st pic is where I started and 2nd pic the finish.
Cheers
Si
A longer stem and bent arms would help with aero.
Aero doesn't matter a monkeys for a non-competitive cyclist. Most of the time you will not even be going fast enough for aerodynamic drag to be greater than tyre and mechanical friction drag. Set the bike up for maximum comfort and maximum visibility of other traffic. Go back 25 years and you'd almost always see handlebars set level, or very nearly level, with the saddle on anything but an out and out racing machine. The current trend of having stupidly low bar positions comes from too many ordinary cyclists trying to kid themselves they are pro racers, forgetting that pros are getting paid to be uncomfortable whilst racing, whereas the hobby or utility cyclists are not!
Hmm this guy is posing top less and carries a mirror to fix his hair... Pretty boy....
Anyway, it's good to play with positioning, a small change can make a big difference.. I suffer badly with pins and needles in my hands (also when not cycling) gloves can help-I've tried many cheap ones (couple of quid each) and did have a pair that seemed to help, but I can't remember which ones (bought about 5 types from planet x in a sale) so it may be worth trying some out, and if a certain pair help then buy a few pairs....
