Ming the Merciless
There is no mercy
- Inside my skull
If you like fartarsing with cables and drivers and trying to GPX files on the thing, they are great
It’s not the 1990s anymore, bike computers have moved on.
My BiL got a new bike computer 2 years ago. It is a Garmin. It hasn't moved on.It’s not the 1990s anymore, bike computers have moved on.
I mostly use a Wahoo Bolt for navigation (which I'm happy with), sometimes a phone + Quadlock (which I'm also happy with), sometimes both.
If you don't need/want all the extra bells and whistles from a dedicated cycling computer, then the main drawbacks of a phone are mounting, protection and battery life. These can all be soved with quadlock + a powerbank + a top tube bag to put the powerbank in. All of that comes to maybe £100 - less than the cost of a cycling computer and a lot more user friendly if as you say you are not the best with technology.
But, since you already have a Bolt, maybe get a friend to show you how to upload routes?
p.s. one extra drawback of the phone is they get more upset by heavy rain - how much this matters depends on whether you keep riding in such conditions
The only problem with that is that I agree with the OP, Bike computers tend to be shockingly badly designed from an end user point of view. If you like fartarsing with cables and drivers and trying to GPX files on the thing, they are great. Compared with just loading a route on Strava or plotting one with google maps, they tend to be massively more complicated. Hence I just use the phone but inside a see-through handlebar case.
If you have only used Wahoo, then I wouldn't make bets about the other brands. Wahoo specifically designed their device to be a mobile phone front end extension, leaving all the complicated stuff including the processing to the phone. That's still broadly the case. Garmin is not the same.I haven't tried Garmin/Hammerhead/Bryton, but I am sure the latest ones are very similar in ease of use.
Nope. The file was on an oldish MacBook. It didn't want to transfer and when it had transferred we discovered that actually it wasn't going into the folder that we had expected it to go to because the UI is poorly designed.In 2021 pretty much all cycling GPS models on the market, regardless of brand, had Bluetooth and in most cases WiFi for download of routes and upload of rides. Cables and drivers for GPX file transfer? You need to have failed to use it correctly pretty badly for that to be an issue.
We couldn't get it to transfer directly from Ride with GPS (which he was using on the MacBook). Instead we had to export the route to a GPX file and then transfer that.Fair enough , but I imagine if I had a GPX file on an 8" floppy disk transferring it would be a challenge too. Most people transfer to and from web services like Strava, RWGPS etc these days.
No - you need to faff about with the Garmin website and Garmin Connect. I rest my case :-)The UI on the Garmin itself (I have a 530) is pretty naff but loading a GPX file onto the device is 2 mouse clicks from the Garmin connect website. The next time the device is turned on and syncs, bosh there's your route. Importing a gpx into the site in the first place is drag and drop. You don't need to faff around with folders.
)My BiL got a new bike computer 2 years ago. It is a Garmin. It hasn't moved on.
Yep. Once you *know* how to use the Garmin, it's not too tricky. However I can see why new users would wonder what the heck they had gotten into.Transfer of routes (or "courses" as Garmin insist on calling them, just to be awkward) on my 530 is seamless from RWGPS, my preferred route planner. Just a couple of menu taps on the GPS. No need to go via the Connect website. (You just need to know which menus to tap - that's the tricky bit*)
Garmin have the curse of being the early leader in the field and maintained backward compatibility. I can see great similarities in the UI between my ginormous 76S (circa 2000, connect with RS232 serial cable) and my teeny Edge 530 ( circa 2020 Bluetooth and Wifi)Yep. Once you *know* how to use the Garmin, it's not too tricky. However I can see why new users would wonder what the heck they had gotten into.
Quite often the problem with things designed by people with a specialist interest for people who have a specialist interest is that they are unusable or at least difficult to use for people coming from a different angle.
A good UI is intuitive and needs no instruction.
