bennydorano
- Armagh
I had the same experience with mine. At first, I thought the bolt was too short then I noticed that the captive nut had not been pushed in far enough. My review of my Deda Dogfangs (I have them on all 3 of my bikes)is here.If it fits there's not a lot to it, though I found I had to pinch it up tight to get the bolt started.
Which is my review and linked to in post #4 above - ha ha!Just for those that don't know.
http://www.slimmerandfitter.com/cycling/deda-dog-fang-chain-keeper-review/
I must be tired did not see link.Which is my review and linked to in post #4 above - ha ha!![]()
It is getting late, isn't it!I must be tired did not see link.![]()
Hi,
Could I ask you - a bit late in the day, I know - whether you managed to fit the dog fang to the Ribble, and - if so - what size?
Thanks.
ColinJ in his unread Dog Fang review said:The Fang is fitted to the bottom of your seat tube, below your front derailleur. They are available in three sizes and you must make sure that you get the right one for your bike. Measure the diameter of your tube if you don’t know it and can’t look it up on the manufacturer’s website. I measured my seat tube by closing a big adjustable spanner on the tube and then measuring between the jaws. Crafty, huh?
NB This measurement is the outside of the tube – your seat post fits inside the tube so that is not the diameter you want!
If you have a bike with a non-circular tube, or one that is an unconventional size, then you are out of luck. The 3 available sizes are 28.6 mm, 31.8 mm, and 34.9 mm.
