Just flag down another cyclist they will help you.
That's OK if there are other riders around. As I'm retired I ride during the time most people are at work and I also ride in rural Cheshire.
I rarely see another cyclist, except at weekends.
I was under the impression that they would fix a puncture. Even getting home would do though. Unlimited call outs seemed reasonable too for a very good price.I dont think ETA fix the bike but they do get you home, to a station or a bike shop. I have it too, £18 a year
Don't think so no. They just arrange a taxi essentiallyI was under the impression that they would fix a puncture. Even getting home would do though. Unlimited call outs seemed reasonable too for a very good price.
In that case the best option would be the one quoted below, plus some sort of Marathon tyres.That's OK if there are other riders around. As I'm retired I ride during the time most people are at work and I also ride in rural Cheshire.
Taxi home on the odd occasion you puncture is still probably the best option.
Are the tyres easy to fit? Any special tools needed for this?I concur.
Great tyres and never get a puncture. You do have to be wary that the 25mm versions need a minimum inner rim width of 17mm.
They are a doddle to fit once you know the ‘trade trick’ technique. The tools you need come with the tyres. The technique is basically to pre stretch the tyre by standing on the bottom of the tyre and pulling it upwards a few times using the supplied ‘super lever’ as a lever through the top, then putting the tyre over the rim and attaching it by pushing the locating pins into the rim as per supplied instructions until you get to the point where the tyre won’t naturally go over the rim. Then stand over the wheel with your legs spread wide apart, and feed the rest of the tyre over the rim by leaning down using your elbows against the rim for leverage. There is another way as well which is basically pre stretching the tyre as before, feeding and fixing the tyre as far as possible then feeding the lever under between the tyre and rim at the point it’s resisting and standing with your toes trapping the bottom of the rim whilst lifting the remaining tyre into place like a ‘resistance band’ then locating the remaining pins. It takes a bit of practice, but you won’t need to do it again, as the tyres tend to outlive most rims expected mileage anyway. Getting them off ( should you want to ) is actually child’s play as well, once you know how. The thing you have to remember is that the 25 mm versions need a minimum 17 mm internal rim width, and you may need to ask the suppliers to supply the peach coloured s pins that don’t normally come with the 25 mm tyres. The 23 and ( oddly ) the 28 mm tyres will fit a narrower rim.Are the tyres easy to fit? Any special tools needed for this?
I have Marathon Plus tyres on one bike
In the OP's circumstance, I'll add myself to the Marathon Plus team (get the LBS to fit them). Very very low chance of a puncture provided sensible pressures are maintained/checked. You can get them in many widths and diameters (including the OP's requirements.+1 for Marathon Plus recommendation.
That'll be "no" (unless you have the hands of a crab) and "yes" then. Perhaps the OP's LBS will fit them, but I suspect not for free. Tannus tyres seem to offer the opportunity, nevertheless, to move from a very very low chance to 'nil'.The tools you need come with the tyres. The technique is basically to pre stretch the tyre by standing on the bottom of the tyre and pulling it upwards + + +
Nothing is 100 per cent puncture proof.
all the way OR phone the good lady wife to rescue you, major
