Puncture "proof" tyres for rock
Alun
Liverpool
I've got Nobby Nic Evos and they are great for British mud, they are kevlar bead and go on my rims without any fighting. I think for Spanish conditions, you could get away with a lighter tread though. I would go for puncture protection and wouldn't use lightweight tubes due to all the thorny foliage. Have you tried Co2 cylinders, I'm a convert, but still won't go out without a pump.
lulubel
lulubel
Malaga, Spain
To be honest, I can't see the point of them for MTBing. I can pump the tyre up harder than I need with a hand pump, so using a throw-away cartridge seems like a waste of money.
Road is a different matter, but I haven't needed to change a tube at the roadside since I started using Vittoria Rubino Pro tyres (around 4 years ago), so I've always just carried a "get me home" pump. I have changed to wider tyres now, though, and the Rubino Pros only go up to 25mm, so I've had to get something different. Hopefully, I've made a good choice, and I'll continue with no punctures on the road bike.
Alun
Liverpool
I'm sure you can, but if you're going to get punctures, then a tyre that goes on and off the rim easily and a CO2 cylinder that can inflate the tube without pumping makes life a bit easier. If you buy the cylinders in bulk they're quite cheap www.co2cartridges.co.uk
lulubel
lulubel
Malaga, Spain
Well, the point of getting new tyres is to not get punctures, but thank you for the information.
Alun
Liverpool
I've always associated pinch flats (if the same as "snakebite" punctures) with too low a pressure in the tyre, would a higher pressure help?
lulubel
lulubel
Malaga, Spain
Yes, it would, and that's what I've done for now, but it doesn't make for a very comfortable - or controlled - ride.
