Oldspice
What has that got to do with fixed gear?Breaks and brakes,
yep they do if you lean over to far.question ive just thought of. with a fixed gear do the pedals not catch the ground when cornering??
I only had it happen once, i was about 17 years old at the time, but i still remember it hurting, still waiting for my new fixie to arrive not looking good for the weekend.so what can you do just corner slower i s'pose?
Exactly so, I have 175 cranks on mine as I run a fairly big gear so a bit easier to climb with, I also tipped the bike to see how far I would have to lean to get pedal strike and as Rob3rt says it's a long way. I've done over 32,000 miles on my fixed and never grounded yet and I'm not exactly known for being a careful cyclist, though I would dispute this .Unlikely if you are running appropriate length cranks and if the frame has been designed well (i.e. a higher bottom bracket). I have tipped my fixed over to see how far you would have to lean to get pedal strike and you would have to lean over a hell of a way!
I find, day-to-day, I'm generally a bit slower on fixed but if I put my game face on, as I tend to do a couple of times a week, my pb on fixed is minutes faster than the pb I can get with gears.Purpose built fixed gear bike will have a higher bottom bracket for this reason. Also I swapped the 175 cranks that came as stock on mine for 165s. Both these lessen the chance of pedal strike.
This might sound unlikely, and I can't really explain it, but I'm faster on my 15 mile London commute on my fixed than I am with gears.
