CrazyBrit97
Regular
- Cwmbran, Wales
I grabbed one today and it was too short...Standard SS/fixed/ SA 3spd/BMX chain.
Or a way to clean it good would be niceWhats wrong with the one you have now?
Take it back, 114 links (standard length) should be plentyI grabbed one today and it was too short...
Can't get them off without brakingWhats wrong with the one you have now?
Thank youTake it back, 114 links (standard length) should be plenty
Will be trying that nowOkay here's how to clean it. You will need some brake cleaner / de-greaser a wire brush and an old tooth brush. Remove the chain from the bike, on one of the links there will be a small "U" shaped clip, get a screw driver and pry it off, then remove the small plate under that that holds the links together and the chain will come off the bike. Now you want to put the links back together so the chain is joined again. Now place the chain onto a flat surface and sort of roll it up making sure it's flat against the table. The you want to put the chain in a vice and tighten the vice enough to hold it in place but not too tight that you damage it. Now use your wire brush to clean all the thick grease off. Use an old toothbrush to scrub it with de-greaser too. Once one side is clean flip it over and do the other side. Now you have most of the dirt off dip it in a pot of de-greaser to get all the loose bits out. Then dry it with an old cloth, spray it with some WD-40 and it will be as good as new and ready to put back on the bike and use.
Thank you so much I just got it off and cleaning now!! This chain has been in the way for ages ahaIn the picture I just posted of the cleaned chain, can you see the U clip I'm talking about? Look for that and pry it off. The way the chain is rolled up like that is also how you should have it when you put it in the vice.
ok, so it all going good so far and the bike is coming along and the frame is in greatish condition as you can see View attachment 112387 but the mudguards are in terrible condition look wise (they still work completely fine) as you can see they are rusted and i have washed all the dirt off View attachment 112390 View attachment 112388 View attachment 112389 i was just wondering what is the best option here... thank you![]()
