Can you give me an example of a relevant and imaginative question pleae.
If I was a design student I'd rather expect to be able to think of one for myself.
Mind you, I'd expect to be able to spell.
You could think about obstacles to cycling, for instance, or any fundamental changes to bike design or construction - perhaps cross-pollination using ideas from other industries or fields. I'm thinking here of ideas like bringing in a ski-binding company to invent the Look clipless pedal, or using the Hirth joint from F1 crankshaft construction in the Campag ultra-torque chainset.
Asking about gears and brakes is just fiddling around the edges. Use your imagination.
An automatic gear box will still have a certain amount of gears. You don't want big jumps in ratios and at the other end you don't want to be changing gears all the time as it can reduce efficiency.
Continuously variable transmissions are commonplace, but maybe not on bikes (NuVinci drive notwithstanding). I love the way
you're telling
us what we don't want in a bike. You don't actually appear to have a scooby what people might or might not want.
I plan to design a vehicle for the road and not for off road. The survey should perhaps of included other cyclists but I thought my main target market would be commuters.
Should have, not should of.
Anyway, I look forward to seeing your design once it's done.
