lulubel
- Malaga, Spain
I've already posted about my wobbly cassette and have looked into and tried everything discussed in this thread.
Nothing has worked. I've taken it off, put it on (with and without a spacer), made sure everything is lined up properly, checked that my 11-tooth sprocket and my hub are compatable. It's really, really tight - I mean extremely tight! - there's no chance that I'm not tightening the lockring enough.
When I had the wheel off and the QR skewer out today, I wobbled the cassette again while holding both sides of the biggest sprocket, and I noticed that everything moved. Even the lockring moved relative to the hub.
Would this happen if the problem was a loose cassette? Or is the outer part of the hub that the cassette fixes to moving relative to the inner part?
Do I have a problem with the hub (which was brand new when I built the wheel), and if I do, what can I do about it (preferably that doesn't involve a new hub and rebuilding the %(*&ing wheel)?
(It's a Shimano 105 hub, just like this one.)
