- London
OK - but surely depends on the gradient/the gradient increase.OK, next time you're out, try starting a hill by spinning, Then stand up without changing gear and see if you can get your legs to go round as fast.![]()
Don't worry. It's par for the course here.Erm, I seem to have opened up a rather hot and touchy subject. Genuinely didn't mean that. I was really just checking that a chain of my mileage is unusual, but not unheard of
What is wrong with just dripping one drop of oil on per link? It is probably easier than faffing about with one of those devices. (I had one years back and it broke after a month or two. I din't bother to replace it.)Has anyone tried filling those clip on chain cleaners with oil? Not to clean, but to relube. I've heard those cleaners strip all of the lube from the chain inbred.
How does the drive feel compared to your bikes with less miles on their drivetrain?
Dumbass question time then, is any 11 speed chain suitable as a replacement. IE can I use SRAM on shimano 105?
cheersSRAM
Shimano
KMC
All interchangeable.
SRAM
Shimano
KMC
The only Campagnolo chains that I ever used were the ones that came with the Campagnolo groupsets on 2 of my bikes. When they wore out I just switched to low- to mid-range SRAM. I have had no problems with them!I think I've got a bit of a bromance going on with KMC. My LBS tried to persuade me that my Campag kit required a Campag chain....at about £40 a pop. I fell for it once but after it had done a couple of thousand miles I swapped it out for the KMC "equivalent". Much tutting and sucking through teeth at the LBS.
But guess what? The KMC chain....at I think £14 a pop has performed just as well as the Campag one, as have the replacements I've had subsequently
