You just need to put less stress on the valve, that's how you've damaged the join.
Possibly a stupid question, but is there a trick to this?
colinr said:Possibly a stupid question, but is there a trick to this?
Yes, I think there is. When I'm pumping up a tyre after a puncture i.e. with my frame pump I always:-colinr said:Possibly a stupid question, but is there a trick to this?
Femto said:Just as a matter of interest; which came first? Presta or Schrader and what's the main reason for choosing Presta over Schrader? Are Schraders too wide to fit into narrow road rims or something?
fossyant said:That's not a nut - it's a dust cover. That blackburn is fine - I've had one for some time.
One - ditch the metal nut on the presta valve which you use to tighten onto rim - that induces stress when pumping.
With the blackburn, you just pop it on the valve, and flick the lever out to lock on.
byegad said:Or change to schrader!
