I find my woods valved tubes lose air quicker than either presta or schrader. I was under the impression that resta more more suitable to high pressure systems - did I make that up?
I'm not sure why that would be: Presta valves are held shut mainly by the air pressure differential (which is why the locknut is needed, to stop it bouncing open in use) whereas Woods and Schrader are generally spring-loaded these days.
Isn't the main reason why higher-pressure bike tyres use Presta is that they're usually on narrower rims and Presta valves are something like 2mm narrower, so there's more rim left which makes it a stronger wheel?
I can't find many comparisons of tube air-holding that uses all three valve types, but on the boxed tubes I have indoors, the Impac Woods one says to check pressure every 14 days and the Coyote Schrader box says regularly, whatever that means. I check my roadster (impac Woods) weekly but there's usually minimal change from 60f 80r - the air I have to pump to open the valve enough to get a reading seems sufficient to top it up! I check the road bike (Vavert Presta at the moment) every ride (roughly weekly) and it's usually fallen from 70f 85r to 60ish in a week. Of course, this could be Vavert being dud tubes or that my vintage bike's 28s don't run at high enough pressures to hold the valve shut, but it seems like most people top up their road bike tyres often.
