T.M.H.N.E.T
- Northern Ireland
Just out of curiosity what has the temperature to do with power? Is it something to do with the sensor?
Shaun
Measuring power is simple in a controlled environment, but when you’re out in the elements facing varying climates everything changes. The strain gages used to determine power, whether it be crank based, spider-based, pedal based, etceteras, are highly affected by changes in temperature. If a power meter system does not take into consideration changing temperatures throughout a ride, power will be wildly inaccurate.
Why do changing temperatures affect power? Strain gages are tiny metallic wires laid across a metal crank, spider, pedal etc. It is the flexing of these wires that measure torque. When these wires heat up or cool down in response to external temperatures they naturally expand and contract. This results in false data.
Stages Power meters are equipped with ATC – [Active Temperature Compensation]. Different temperatures cause strain gages to expand and contract a specific amount. ATC allows the power meter to compensate for temperature changes that would otherwise affect the strain gages and their ability to accurately measure force. More importantly, Stages ATC auto-adjusts on the fly, without the need to stop pedaling.
And being the owner of a stages, I usually leave my bike outside long enough for my garmin to fix gps (glonass turned off) and lock the front door. Get on and ride with no noticable adverse effects.
