Thanks all
I don't think there is an issue with air in the system, however I do have a bleed kit so can try that.
I hope the attached image shows the condition of the discs clearly enough. I don't think its an issue with rotor as these are the third different set I've tried (unless I am doing something wrong each time) - in general I try to brake fairly firmly rather than gently. In terms of bedding in the pads/rotors, I did this each time by riding down a nearby slope a few times, breaking firmly to a near stop a number of times. The performance increased significantly during this process, but is still lacking compared with my other bike. I also do not think it is a contamination issue, as this affects both the front and rear brake - the front brake is well away from all the oil/lube etc so I cannot see how that could happen.
I hope I've answered all the questions. I appreciate your reply's.
Cheers
Dave
Cheers
Dave
