Plunge taken... so TT advice required
lejogger
Wirral
Ok, some of you might remember my previous procrastination about whether to remain a Strava obsessed joy-rider or actually bite the bullet and put myself up for some proper TTs.
Our club are holding a couple of open 5mile TTs tonight and next Tue, so I've dusted off the carbon, fitted a new chain, stuck on some GP4000s and put my money where my mouth is.
Obviously for a first go I'm just looking to set a benchmark to improve upon, but I'd be very grateful of some advice in terms of preparation and the event itself, bearing in mind that it's a very short route.
Cheers folks
Rob3rt
Man or Moose!
Manchester
No real advice but Good Luck :smile:
lejogger
lejogger
Wirral
Cheers :thumbsup:
My current plan is to melt down a Cadburys Boost Duo and inject it straight into my bloodstream (possibly via the eyeball), perform a few roadside lunges and a perhaps a squat thrust or five for a quick warm up, and then PLF!!
Nosaj
Rayleigh
Warm up well, Get your HR well up in the warm up by short little sprints, you should go off at one minute intervals (double check when you sign on) and you should time so your warm up ends a couple of minutes before you strat. Do go off too hard from the start or you will go pop, try to get to the end line feeling like you have nothing left to give, a recce of the route helps.
Do not worry about the first time you get, you will obliterate it if you do em regulalrly.
Turn up early enough to allow you to sign on, pin your number on, warm up and get to the start (around an hour ish)
And most importantly enjoy it (well enjoy it when it is all over)
Good luck
Ian H
Ancient randonneur
For club events where you just turn up and sign on, try to find a suitable 'rabbit' to chase. In other words try to sign on after someone who might be just a little slower than you. Then your aim is to catch them as quickly as possible without blowing up.
Nosaj
Rayleigh
Yes very good advice above, try and not go off no. 1 you will put so much more in chasing someone down
The best position to end up in is to have someone almost around your time but a tiny bit quicker (literally a second or two) off as your minute man as you will do all you can to reel em in and this can lead to a good time), someone 2 mins slower than you in front of them and 3 minutes slower than you in front of them and so on then you can scalp all the way round there is no better motivation for tired legs when you see someone with a number on their back ever so slowly getting closer to you.
lejogger
lejogger
Wirral
Cheers guys.. just prepped the bike and taking on a little fruit. No idea what the standard of rider turning up will be like so it will be down to luck what the guy in front of me is like.
Got a few nerves but that's no bad thing!
palinurus
Velo, boulot, dodo
Watford
Cheers :thumbsup:
You've got the right idea. You'll do fine.
lejogger
lejogger
Wirral
Well just got home... posted an 11:43 for the 5 miles, and picked up first prize!!! :wacko:
Shocked and over the moon! Cheers for the advice guys, it obviously worked wonders!
lejogger
lejogger
Wirral
Went off at one minute intervals and had a feeling I'd catch the rider in front so focused on reeling them in, which I did in the first 4 minutes or so. I definitely went off a bit fast but realised early enough and managed to get into a steady tempo. Definitely gave it everything... I was dribbling all over myself on the home straight and panting for what felt like half an hour at the finish line. The route was only two miles from my house and it definitely helped that I knew the roads.
Well I'm not sure how I can improve on that one!
Mixed feelings. Part of me never wants to be in that pain again, but it was a really great feeling to have people telling me I was still top of the pile when more and more riders came in.
The biggest problem now is that despite all the guys in skinsuits, TT bikes costing £000s and teardrop aero helmets, I beat them all on a Boardman Team carbon with a cracked saddle, standard non aero ritchey wheels that don't even have bladed spokes, and a £30 set of profile aero bars that look like the ones Lemond used to beat Fignon back in the 80s! How can I stop myself spending money to get even better times!!
atbman
Ah, so there's the answer - a cracked saddle.
If I was riding on one, I'd go as fast as possible to cut the pain short.
As for the equipment question, simples. Don't change anything, but keep on training until your times only improve by a second or two. Then get new equipment. Your times will improve immediately. Then keep on training until your times only improve by a second or two. Your times will improve immediately. Then get even more expensive new equipment. Then keep on training until your times only improve by a second or two. Your times will improve immediately.
Repeat until become international (they will give you even more expensive bike(s)) or until credit card transaction is refused. then concentrate solely on training.
lejogger
lejogger
Wirral
Excellent advice. I guess it goes to show that the kit doesn't make a huge difference, it's got to be a high percentage down to the legs, so I'll hold off on the kit for a while...
...except for a saddle. It appears that's quite urgent now!
