Deleted member 23692
I've got 38mm tyres and mudguards on my LR
Just buy one
Just buy one
This is a hard sell, when it shouldn't be 😂I've got 38mm tyres and mudguards on my LR
Just buy one
I actually think the LR isn't that cheap. £899 for rival - £20 delivery. + Guards & Pedals
The decathlon RC520 has slightly better spec for £750
The giants contends even at full RRP - are comparable - and last model is available for £700
That said if it were on c2w I would buy the PX - But at £899 itd decent but doesn't strike me as a "Do not miss"
That doesn't bother me too much- I am not sure how much you gain from 45 mins on a bike - when typically you will be riding it 3-4 hoursAnother negative thing about any Planet X is that you can't do test rides so, unless you know someone who has the same model you want and kindly lets you try it, it's always going to be a shot in the dark.
Read up about the wheel/tyre issues on the decathlon bikesI actually think the LR isn't that cheap. £899 for rival - £20 delivery. + Guards & Pedals
3-4 hour commute? KudosThat doesn't bother me too much- I am not sure how much you gain from 45 mins on a bike - when typically you will be riding it 3-4 hours
I thought this is a C2W commuter?3-4 hour club runs or training rides in winter weather...
??The internet is a big place. I could read up on planet X customer service or London road mudguard issues.
PX certainly aren't amazing in that regard. They wanted my entire bike back to look at a minor issue with the front fork (the rivsert for the mudguard had loosened). In the end I got the bolt as tight as I could and strategically laid two cable ties across the mudguard to make sure it never vibrated out. That was sept 2015 😂 no problems since.??
It was a suggestion. You may already know that the wheels can be problematic in terms of tyre changes for puncture repair (you may not want to use M+ on your club runs for example or even commute). There are several long threads on here. If you’re aware, unconcerned, it’s a good vfm option
From what @T.M.H.N.E.T says, there are mudguards to fit the LR
And no companies are perfect of course. It’s how they handle issues that separate the good, acceptable, less good
