Pitlock Or Pinhead!!!!!!!!!!!!!!!!!!!!
M
maroon
Same here - Selle SMP was the end of my search, after several years of agony trying at least 8 different models of Brooks.
Agreed I love the concept of brooks saddles but. Ya can't beat a selle saddle
andrew_s
Gloucester
I'd normally recommend that, having finally found a saddle that suits, you get a couple of spares, on the grounds that when the one you are using wears out, they will have been replaced with a new! improved! differently shaped model that doesn't suit.
But at that price, maybe not :sad:
Crankarm
Nr Cambridge
Just in case anyone is thinking of getting Pinhead locking skewers - DON'T! A bike thief can easily undo them in a matter of a few minutes. There are a few videos on Youtube showing how crap they are. Avoid. I have Pitlock skewers which are harder to open as they require a shaped key to undo the skewer which has a reciprocal shaped nut inside a housing making it difficult to access. Far better than Pinhead, although I still don't take them for granted and use 2 Abus Granit D-locks as well to secure my bike. I remove the saddle which has a simple QR collar figuring it will be less attractive to a thief to try and ride a bike without a saddle. It does mean I have a saddle to carry around, but it's not that onerous. HTH.
I do pick up used ones on eBay from time to time, but they're never any colour other than black.
M
maroon
I've started using Hexlox
This is an update of the old trick of supergluing a ball bearing into the socket of your allen bolts, but with the insert readily removable with a small coded key that's only about 15 mm x 3 mm dia., taking up hardly any keyring space.
You can protect anything that's fastened on with an allen bolt, not just wheels and seatposts.
Thanks @andrew_s @velovoice just returned from the wonderful Seabass Cycles where the guys there sorted me out with a Hexlox system really good service and more than happy .... let's hope it works thank you.
Seabass
Member
Hi everyone, just thought I'd jump on your thread to let you know that we have all sizes of Hexlox back in stock. There's only a couple of places in South London that sell them (one or two more across the river I believe) so if you're passing through SE5 come and say hi. We also now have the adhesive/magnetic inserts which allow the Hexlox to be fitted to non-magnetic (ie stainless steel) hex bolts. These are available in 5mm and 6mm, but not 4mm.
Great to meet a couple of you who came into the shop, thanks again for your support. Best, Simon
M
maroon
Hi Simon
The plug alone surely must be worth the T shirt I was after x large please
