Nigeyy
- Massachusetts, USA
Apologies in advance for the long post....
So... cycling along on the trails, and I realize it sounds like I have a can with a ball bearing in being rattled around whenever I pedal. In fact, it sounded so much like this, I stopped, removed the seatpost, turned it upside to shake it, half expecting a bb or some piece of metal to drop out... none did. After some experimentation, I definitely narrowed down the sound to the bottom bracket area, and only when I pedaled.
At this point, my biggest fear was a crack in the frame, and after getting home I inspected the frame closely, but I couldn't see any crack (thankfully!). I took out the bottom bracket, everything seemed smooth so I cleaned the bb threads, put new antiseize on, tightened the chainring bolts and put it all back together... to hear exactly the same problem. I tried putting different pedals on to rule out the pedals, still the same pinging noise. Again, at this point, I was again worried the frame had a crack. I removed the bottom bracket, and actually put a spare one along with a spare crankset I had on the bike, and success! The noise was gone -so it is the bottom bracket or crankset. But was it the bottom bracket spindle or the crankset? Which one?
I put the offending bb in a vice, and then put the non drive side crank arm on and gave it a pull... no noise.... put on the driveside crankarm -and ta da! There was a pinging noise when I pulled on it. I repeated this to make sure the bb wasn't somehow slipping and got the same result. I also really tightened the chainrings again just to make sure, but again I got a pinging noise. The crankset is toast; no way would I continue riding that with the suspicion there's a nasty metal fatigue crack in it!
At this point, I have to point out my drivechain is 9 speed and the crankset is an early 2000's Shimano LX octalink -and while I've done many miles on this crank (3rd set of chainrings and second bb) I couldn't find an equivalent replacement after googling. In the end I got a Shimano M610 with external bearings for around 40 quid*, including bb. Since the octalink bottom bracket still seemed very smooth, I donated it to a mechanic who supports a charity ride, so I was quite happy with that.
This was also my first foray into mixing and matching 9 speed drivechain components with a 10 speed specific crankset; I'd read some people need 0.6mm spacers for this, and some people just found it worked. I just went with it without spacers (though the spacing is definitely slightly tighter) and can confirm the shifting is fine (Shimano 9 speed RapidFire shifters) and I had no chain rub! Of course, YMMV.
*yeah, about that forty quid. I also replaced the cassette and chain as well as they were pretty old. So I did end up spending quite a bit more.
