How long do you need to ride for? My Varia lasts at least 12 hours on daytime flash, it may go longer, I have never checked.
Slightly OT...I'm running 28s on the Scott at the minute, giving 1mm clearance twixt tyre and seat tube. No issues so far, but...I decided 1mm of tyre clearance wasn't a sensible amount
I spotted a while back that Hope had released a new variant of the flatmount rear RX-4 caliper without the +20mm offset that had caused me issues in the original build, and required switching the rear caliper for a post mount with a homemade adapter bracket. I ordered one ages ago but have only just gotten round to fitting it. The zero offset caliper mated to the +20mm frame mount means I can now run the rear 180mm rotor with no bodgery
Of course I swapped my purple piston caps in to the new caliper before I filled it with mineral oil 😊 These new RX4+ calipers are supposed to be easier to bleed, but this one still showed some resistance
I took the opportunity to give her a good clean too, with the cassette and chain spending 20 minutes in the ultrasonic cleaner for good luck
