AM1
- Sunny Stockport
So you have that ' before and after' face then
Get them seen to, the first thing is to make certain the bleeding is only from the piles. Piles come are either intenal, which become apparent when they bleed or external, the ones that are more noticeable pain wise. I ended up having to have an operation to remove what the surgeon described as very large internal ones. Cause as has been noted can be straining too much, but equally a spell of very loose bowel movements can equaly cause them.Thankfully I don't suffer any pain with mine, just copious amounts of bleeding. I've not really figured out the cause although I can rule out long distance cycling as it doesn't seem to matter if I've done 100 miles or not looked at a bike for weeks.
I did use suppositories for a while which seemed to ease the bleeding a bit but now I just manage it as best I can.
