Mr Pig said:
I've read the sensational reports concerning the forces exerted by the disk brake and they all failed to take into account one very important factor. The weight of the bike and rider pushing the fork into the ground under braking, which renders the scaremongering largely irrelevant.
You need to do the maths to understand. The weight on the front wheel is rarely more than the weight of the rider and bike combined, the exception being if you've just run into something. The force created by the caliper is larger than this - for a given deceleration it's greater with a smaller disc - and there is a net ejection force. With a steel fork the lawyer lips can take this sort of abuse, but maybe not indefinitely on an aluminium or magnesium fork leg.
The manufacturers (Marzocchi being an exception) refuse to admit the problem because it would probably result in the biggest recall of bikes in history, as well as requiring a new International Standard.
Jobst Brandt worked in the original automotive disc brakes for Porsche, so knows a bit about the subject:
http://yarchive.net/bike/disk_brake_qr.html
I have the QR lever on the left and it's tucked under the caliper in such a way that it cannot loosen. It's also a steel fork with lawyer lips and the skewer is one of those old Shimano jobbies, well-oiled and done up tight. It will hold, I'm sure.
