mcshroom
Bionic Subsonic
- Egremont, Cumbria
At least with usb-c the cable works either way up, which means it's only the usb-a end that you'll need to plug in 3 times to get the right way up.
My first proper job after leaving college was testing and fault finding Dell laptop motherboards which had been returned under warranty.At least with usb-c the cable works either way up, which means it's only the usb-a end that you'll need to plug in 3 times to get the right way up.
Well they did get their fingers burnt with the Note 7, so to speak.You may find that your new cable charges the phone at a completely different speed so it's not all disadvantages to the original. A new one might be a bit or a lot slower. Samsung generally are very slow at charging due to being very conservative with charging tech, so it doesn't make much of a deal for me (wireless charging).
Thunderbolt 3?Of course Apple will be late to the party.
USB C, currently they're protecting their licensing income from their own connector rather than using an open standard.Thunderbolt 3?
@marinyork I had no idea there was a setting to stop fast charge......I assumed the phone was simply a faster charging model.
Do you think it is something I should do?
I used those adaptors. For some reason they always stopped charging on either exactly 80% or 90% charged. I even went back to the Samsung store and they had no idea why. I ditched the adapters and bought proper cables. No further problems.Amazon - Search For Anker cables. - Just got 6 for £9.99. We have a mix of USB C and Micro USB, so I bought a pack of 5 Micro USB to USBC adapters. They come on a little chain that you clip to the cable, so you can charge both types.
It will be USB D next week.
