subaqua
What’s the point
- Leytonstone
washing up liquid solution with vinegar works great as a degreaser.
paraffin is very good and cheap ,,heater oil by any other name ,,u can even get it in bnq ,,much cheaper than petrol
I could be wrong but I think I read that diesel is a good chain cleaner and also leaves a bit of lube on the chain as a residue. Did I imagine that?
Generally I think petrol is an excellent cleaner, much better than white spirit, and as it is so volatile, it dries very quickly. Try cleaning paint brushes (oil based) 50x better than white spirits or brush cleaner, and certainly a fraction of the cost of brush cleaner. After use strain it through a face mask and put it in the lawn mower!
Re-use it? You could probably sell it on E-bay
Rag and bit of WD is all you need to clean a chain, then chuck any oil you have lying about on it and away you go
Dont they say dont lubricate your chain with oil cos it attracts abrasive dirt.
I clean my chain by immersing in a vat of boiling engine oil - dry and lube. Same for motorbike.
Never had a chain brake in 10 years couriering on a gt550 - dya get it ?Flippin' 'Eck Tucker!
How big does the vat have to be to immerse a motorcycle in it?
PS. I rode a Guzzi for years. Electrics were awful, but I never had any problems with the chain. Credit wjere it's due; Guzzi chains must be excellent!
Plus gts were shaft drive = no chain .
Brave man going out on a guzzi in the wet.
