Ajax Bay
- East Devon
This.The cable adjusting bolt should only be used for fine tuning the indexing, not making major adjustments.
Cables do not 'stretch', not even while 'bedding in'. Securing points and the outers the cable passes through might affect this though.with a stretched gear cable
This (beaten to it by @smutchin ). Don't worry about the spring. Cable tension holds this together. If the design includes a spring (and this one clearly doesn't as it is not present and there has been no opportunity to lose it) it makes the adjustment a bit easier.Not all of them have springs.
It is quite possible that the threads have been damaged as you incrementally unscrewed it and tested the RD. At the end (ie before it finally came apart) there would only have been a couple of threads engaged and the bending moment on the 'bolt' element would have damaged either its threads or, less likely the tapped hole in the RD. Looking at the diagram, it's possible the hex nut has twisted in the knurled body and is not square on to the bolt, thus preventing it screwing in. @smutchin has given advice there: poke out the nut if it will come out and screw it on first. I think it more likely that you'll have to square it up in situ.
HTH
