Roadhump
Time you enjoyed wasting was not wasted
- The flatlands of South West Lancs
A couple of months ago I had the chain, cassette and front rings replaced on my bike. Not being a bike mechanic, I had this done at the LBS. Last week I was out riding and whilst going up a steep hill wanted to change into the lowest gear available, but the chain wouldn't go further than the last but one largest cog on the rear cassette. When I returned home, I had a look at the internet to see if I could teach myself how to adjust the gears, and found a few videos which all gave the same advice about indexing using the barrel adjuster.
I followed that advice, which seemed to work okay, but then I found a loose spoke on my rear wheel so took it to the LBS where the spoke was fixed. When I put the wheel back on I found that the gears wouldn't change properly, the chain wouldn't go further than about the 4th lowest gear on the rear cassette (4th biggest cog) so I tried to go through the process of indexing again. This time I found the shifter was very stiff when trying to change down and basically the whole thing became useless. I looked at either end of the cable and whilst the shifter end seems okay, the end by the derailleur seems to be broken. The barrel adjuster seems to have fallen apart and there is now a threaded piece of metal about 1 cm long around the cable which appears to be designed to screw into the barrel adjuster housing. The cable still runs through the barrel adjuster and is attached to the bolt that secures it to the derailleur, but no matter how hard I try I can't screw the threaded piece back into the housing and consequently the adjuster is now useless. The metal doesn't spin around the cable which means that to screw it into the barrel adjuster I would have to rotate the cable several times which presumably would just twist it.
If anyone knows a solution to this I would be grateful for any advice, but I will probably just go and spend more money in the LBS to get it fixed.
