shouldbeinbed
Rollin' along
- Manchester way
Heat or more oomph. Vice and extension bar again if possible.
Could the problem be crossed threads?
You undo them by turning the spanner towards the back of the bike on both pedals
Only if spaner/Allen key is above pedal, if you turn towards the back with spanner/Allen key below pedal it will turn the other way.
I thought using torque wrenches to loosen stuff was a very bad idea?try a long torque wrench with 8mm allen bit fitted
maybe it is, can I change that to very long handled wrench? My torque wrench (the click type) keeps going after the click - does it get damaged if you do that?I thought using torque wrenches to loosen stuff was a very bad idea?
But the drive side pedal is righty tighty lefty loosey so turning clockwise tightens it. I an looking from the pedal side of the crank arm
