I’m just gonna lob a bit on a wiggle it about a bit.
I'm sure that's got to be at least 95% as effective at ascertaining its suitability as other methods
I put the anti seize grease on ours yesterday and a test clamp on it. All seems to be in good order now.
Good work - will be interested to hear how it goes!
Likewise I removed the silicone grease from mine today and it works properly now; just hope it behaves itself..
I think the lesson I’ve learnt from reading above links is keep the pivot loose when not in use.
An update to my original initial review which was probably a bit harsh all things considered.Tried another ALDI store this morning and they had stock - price is on Sale at £19.99.
They did not have a stand on display so I took my chances.
The good: the price is a bargain.
The bad: I have just assembled and IMO it's not really fit for purpose.
The main issue is the pole that connects the claw to the main upright twists as soon as you put any pressure on it such pedalling the drive chain.
If you look at last years model the pole has a serrated finish which creates friction with the clamp (you also get the same serrated finish on the Halfords version mentioned in this thread).
https://www.aldi.co.uk/bike-assembly-stand/p/811579578216200#product-reviews
The one I've purchased has the same overall design but all parts are black, however the connecting pole is completely smooth.
The claw is narrow in depth and of course the rear brake cable inevitably is seized when you use it – I had the same rear-brake issue with an old Park Tools 9 stand I borrowed from a neighbour so probably not a deal breaker.
The claw has 4 small rubber pads - I did not feel confident using these rubber pads – I felt there was a risk of damaging the frame when using them.
The claw itself works fine but I'd be surprised if it lasted past the 3 year warranty.
It has 5 legs which enhance stability but take up a lot of floor space - if you're tight for space you should avoid this stand.
Included is an optional non-magnetic tray and a pole for securing your handle-bars.
I've noticed Park Tools can be picked up for a song now.
PCS 9.3 or the PCS 10.3?
Is the PCS 10.3 worth the extra money?
Difference in price between them is £30. Agree, it does look better.Can't allude to prices or differences in spec, although when I bought mine the 10.3 looked like the better buy.
I wonder if the heavy discounting is reflective of updated versions being eminently launched?
