Globalti
One of the most common causes of wrist pain is a maladjusted saddle. Your saddle is designed to support the greater proportion of your body weight. It can only do this effectively if it's absolutely level. If it's nose up every push on the pedals will push you backwards off it and you'll struggle to put any power down. Nose down causes your arse to creep off the front of the saddle and the only way to resist this is by pushing back off the bars. This obviously adds to the weight of your upper body which is already being transferred through your wrists. If your saddle isn't comfortable when it's absolutely flat then either you're on the wrong saddle, or it's the wrong height or your cycling shorts aren't doing their job. (Or .. your arse just needs a few more miles to toughen up).
This is the best advice on this thread. The saddle should be flat or even nose-up by a degree or two so that your pelvic bones are cupped and supported. Once you've got the saddle right you can start thinking about the bars.
