Arch
Married to Night Train
- Salford, UK
abchandler said:Or, start at a pole, and you only need one
No, you need to start with a chain joined round into a circle, so a minimum of 3...
Arch said:No, you need to start with a chain joined round into a circle, so a minimum of 3...
abchandler said:I shall log that as my craft fact of the day![]()
Glad to be of service.
cisamcgu said:It is the same for both, and it is, I think, about 16cm .. Which I find astounding... 40,000KM .. add a metre and it raises by 16cm !!!
TheDoctor said:It's about 6 inches . Use the formula for circumference of a circle
Circumferance = diameter times pi
If the circumference increases by a metre, or 39 inches, the diameter goes up by (39/3.14) inches or just over 12 inches, so the radius goes up by half of that.
Checking on a calculator...16 cm is right.
Speicher said:How long does it take to rise 16cm? If you lift one bit to 16cm above the earth's circumference - how long will it take for the rest of the string to respond to the lift effect. Do you need to extrapolate a wave effect, ie lift the string more than 16 cm to start. What is the velocity of the wave in the string? What about the string that has been in contact with water, as it gets heavy due to absorbing water? Will this affect the lift?
