Rob3rt
Man or Moose!
- Manchester
I find Luganos skid far easier than gators on my fixed.
I find Lugano grip better in the wet than Gatorskins
whereas I find luganos puncture in the dark and wet far more often than gator hardshells!I find Lugano grip better in the wet than Gatorskins![]()
Used Gatorskins through winter on some terrible roads and got my first puncture yesterday on a century ride. It was a pinch after cycling over some gravel on a B road. They have been bomb proof and ridden in all conditions including plenty of wet rides. Can't fault them durability wise as they have done 1500 miles since fitted and punctured once riding gravel.
Performance wise they do not roll as fast as top end tyres like Vittoria open corsa cx's or Michelin pro 2's. They are meant for training or rougher roads though not pure performance.
I would recommend them but for a few extra ££ you can get the 4seasons which are slightly better.
I used a 4 season as a rear tyre for about a day. The 4 season is similar to a GatorSkin but it uses a kevlar bead instead of the wire bead of a GatorSkin. Certainly they both have a duraskin sidewall and I suspect this is where the trouble starts with 4 season/GatorSkins. The sidewall is very firm. When riding on a chip and seal road in the dry it felt like the rear wheel was squirming about. I even stopped to check the tyre was seated properly. I replaced it the next day with a Bontrager Hardcase. I have ridden those until the rubber has come of the carcass and then carried on with no punctures and predictable grip.
horses for courses
None of the Grand Prix tyres are for Grands Prix either. And the Supersonic range aren't quite.I see the Ultra RACE are not for raceingand the ultra SPORT is not for sportives
- and are the Gatorskins made of ........ ?None of the Grand Prix tyres are for Grands Prix either. And the Supersonic range aren't quite.
marketing BS is a funny old thing isn't it?- and are the Gatorskins made of ........ ?
The difference is not in the bead, gatorskins come with a choice of either a wire or kevlar bead. The 4 season tire uses a compound that is designed to be suple in low tempratures, it has a Vectran puncture protection layer. The Gatorskins come in two designs for clincher tires. both have a poly x breaker which is wider and thicker . The Gator skins now come in a hardshell format, with an extra layer of protection on the sidewalls. I use the duraskin version and really like them, but have heard the hardshell version has problems with how it feels.
Either way, they're crap.
