One for ladies only
Sauce pot
Regular
I would like to know what type of bra the ladies wear? Is it just a normal everyday bra or a sports bra? Is it for comfort support or a mixture of both? I have tried both and I find a sports bra to restrictive and not enough movement. But a normal bra just doesn't have enough support. Yes I know I'm a little picky but would like some advice from other females.
Supersuperleeds
Leicester
This thread would be so much better with pictures :tongue:
Katherine
Manchester
Sometimes I wear a sports bra, quite happy with Asda's own. Otherwise I wear one that has a high shaped cup so that when I lean forward, nothing falls out! I don't think padded bras look right under cycling clothing.
Keeping an eye on this for moob advice. :smile:
Shaun
I'm sure you will be kept abreast of the situation:okay:
summerdays
Cycling in the sun
Bristol
I'm in the ordinary bra group.... My main problem is getting the top right, looks fine when I put it on but at the end of the day I suddenly notice it's a bit too roomy at the front. Usually solved by either wearing scarves or hooking the top under the bra strap to stop it falling forwards.
welsh dragon
Triumph tri action which is a "regular style" or Sportjock which is more a crop top style, both pretty comfy.
Also have Shock Absorber but need to be Houdini to get into it and once it's one too tired to excercise further.
I tried shockabsorbers. Bloody hell it was difficult to get on, and your right, was too worn out to do anything once I got it on.
byegad
NE England
Go on, I'll say it.
GREAT Tits!
MissyR
Airdrie
I wear shock absorbers (not the car type boys). They have different levels of support so you can choose how restrictive you want them to be!
