Cool. Get on with it then.I’m pleased with the finish, just need to bolt them on
That is starting to look FAB!
Worn, that cassette is absolute toast.I had a couple of hours free this afternoon, I put the old jockey wheels back on so I could fit the chain and I all the cables.
as usual the Weinmann brakes took an age to set up, I hate them!
I managed to have a quick test ride around the close everything worked nicely but the chain slipped like mad on the middle three cogs on the rear cassette. I noticed it was worn but thought I might just have got away with it, so it will have to be replaced
But it’s looking good and once tweaked and completed it’ll be a very nice bike
I thought after all this effort today I deserved a cheeky beer 🍺
Be very aware that with old levers and those brakes it'll be like hitting a brick wall unless you're really careful. Modern callipers are designed for "2 fingers from the hoods" braking, you grab a normal lever and Aaaaaaaaaaah.DAMHIKTInterestingly only in the middle three gears, so it was probably commuted to death and probably why it stopped being used, a typical Oxford bike!
I’ve also bought some used RX100 calipers, which I’ve used before for these 1980/90’s bikes and are a huge improvement on the crude original Weinmann’s, which although I refurbished I’m just not happy with them. I’ll keep the old Safety levers as they are a nice original feature.
So as usual the costs are rising, but It has to be right, especially as it will be going to new owner.
I see that they have a greater lever advantage than the Weinmanns.Interestingly only in the middle three gears, so it was probably commuted to death and probably why it stopped being used, a typical Oxford bike!
