Odd factoids
colly
Re member eR
Leeds
Eating just 57 grams(2 oz) of black licorice, which is about three 2.5-centimeter (1 in) pieces, every day for two weeks can cause heart problems. Black licorice contains glycyrrhizin, a compound that causes potassium levels to decrease. When potassium levels fall, people are at risk of suffering from abnormal heart rhythms, high blood pressure, and even congestive heart failure.
That may well be a fact but the probability of dying from rectal explosion before your heart gives out is almost certain.
classic33
Leg End Member
160g, 12 pieces
Proof that it takes allsorts.
classic33
Leg End Member
According to security equipment specialists, security systems that utilize motion detectors won't function properly if walls and floors are too hot. When an infrared beam is used in a motion detector, it will pick up a person's body temperature of 98.6 degrees compared to the cooler walls and floor.
If the room is too hot, the motion detector won't register a change in the radiated heat of that person's body when it enters the room and breaks the infrared beam. Your home's safety might be compromised if you set the thermostat too high.
classic33
Leg End Member
Shopping is influenced by several subconscious appeals to consumers. For example, if shoppers like the type of music retailers are playing, shoppers will be more likely to enter the store and like the products. Additionally, the slower the tempo of the music, the slower people will walk through the store, and the more they will buy. A faster tempo will encourage shoppers to walk faster and, consequently, they won’t buy as much.
Drago
This is very true. T'is why I never listen to whale song on the motorway, or thrash metal when trying to park in a tight spot.
classic33
Leg End Member
The original Wailers line-up disbanded in 1974 due to Tosh and Livingston's refusal to play "freak clubs." The pair believed doing so would violate their Rastafarian faith.
