Odd factoids
Dirk
If 6 Was 9
Watchet
The only clean shaven member of ZZTop is named - Frank Beard.
Threevok
Growing old disgracefully
South Wales
Goddammit, I just googled teat owl. :laugh:
:laugh::laugh::laugh::laugh::laugh::laugh:
Profpointy
Which in conventional terms (A=440Hz) is more like a sixth of a tone above a G, so it's quite a sharp G. And as any expert on power delivery will probably tell you, the actual frequency delievered will vary a bit, so the shaver (and any other implement which uses AC to deliver vibrations) will sing in different pitches.
Mmm, they keep to 50Hz spot on, but the voltage varies I understand
Tim Hall
Crawley
What you need is N F Simpson's "One way pendulum" with its choir of speak your weight machines.
